WoltLab Suite – Language Update 5.2.3
    WoltLab Suite 5.2.3 Patch for all Multimedia-Pool translations
    It is strongly recommended to update all language files
    ACP (Administration) Customization Languages Import language
    Upload a language file from the local computer: Click on the .xml file you downloaded here.
    Main language file: es.xml, pt.xml, pl.xml,
    conversation language file (requirements): es.xml, pt.xml, pl.xml
    legalNotice language file (optionals): es.xml, pt.xml, pl.xml
    App main language file: es.xml, pt.xml, pl.xml
    infraction language file (requirements): es.xml, pt.xml, pl.xml
    exporter language file (optionals): es.xml, pt.xml, pl.xml
    moderatedUserGroup language file (optionals): es.xml, pt.xml, pl.xml
    Calendar additional language file eventThread (optionals): es.xml, pt.xml, pl.xml
    Filebase additional language file supportThread (optionals): es.xml, pt.xml, pl.xml
